Activity Forums Apple Final Cut Pro Legacy media files not optimized for FCP warning
  • media files not optimized for FCP warning
    Posted by Phil Yunker on August 24, 2009 at 1:36 pm
    Hello,
    I’m exporting approx a 53 min edit from FCP 6.0.6 as a Pro Res HQ 1920×1080 60i and Pro Res 422 1920 x 1080 60i file when I import either one of these clips into FCP I get the warning “the following media files are not optimized for Final Cut Pro.”
    I’m on a MacPro 3.2 quad core
    16gb RAM
    exporting out to a CalDigit VR 3TB Raid set at Raid 0 (I have the footage backed up on another drive)
    The Caldigit is connected to the MacPro via FW800.
    Why am I getting this message?
    Another issue that I’m having with the same clip is that when I export both Pro Res Versions, HQ and 422, the first :20sec of the clip there is no video just audio. I have tried exporting from the initial edit sequence and also nesting the sequence and I get the same results.
    Thanks.
    PHIL Yunker
    Phil Yunker replied 17 years ago 2 Members · 2 Replies
  • Nick Derrico
    August 25, 2009 at 4:52 pm
    If everything is working fine except for the warning, then just go ahead and ignore the message. I’m not quite sure what the purpose of the message is or what it exactly means, but I’ve ran into it before, and it no effect on my project.
  • Phil Yunker
    August 25, 2009 at 6:00 pm
    Nick,
    Thanks for the info.
    Guess it’s one of those “strange” FCP things.
    PHIL
