Activity Forums Apple Final Cut Pro Legacy “media files not optimized” error
  • “media files not optimized” error
    Posted by Andrew Paul bowser on April 9, 2005 at 6:46 am
    I am trying to import a quicktime file exported through FCP 3 into FCP HD and it is giving me an error message that reads “the media files are not optimized for final cut pro HD”
    how do I optimize them? It suggests using media manager? AGH.
    -Andrew
    Jerry Hofmann replied 21 years, 4 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    April 10, 2005 at 2:57 pm
    Export them in FCP HD with the media manager (don’t change codecs either keep them what they were DV?) if you want to optimize them… however they’ll still work without doing this, just not give you as much real time effect playback if you don’t. You can also just turn off the warning.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
