Activity Forums Avid Media Composer media file format question
  • media file format question
    Posted by Baba Goof on May 3, 2006 at 2:04 am
    i might need to be exchanging files with some other workstations soon.
    what format does xpress dv pro save its media in? the original project
    is coming from xpress dv pro captured on a pc based system. the other
    systems work with .avi or .mov files. does xpress dv pro work directly
    with .avi’s or .mov’s? or does it save captured media in its own
    proprietary format? how would i best make the avid-captured media
    available to the other workstations? sorry for the basic questions.
    just wanted to start at the beginning.
    thanks,
    BabaG
    Kenton Vannatten replied 20 years, 4 months ago 2 Members · 3 Replies
  • Kenton Vannatten
    May 3, 2006 at 4:59 pm
    When you capture or import Source material, Avid will create a .omf file that resides in a folder named OMFI MediaFiles on the hard drive.
    What are the other systems you’re referring to? Depending on the nature of the other systems, there may be a potential other workaround to exchange the files.
    Kenton VanNatten
    Avid Editor (for hire)
  • Baba Goof
    May 3, 2006 at 6:51 pm
    the system the project is currently on is dv express pro 4.3.
    the system we’d be exchanging with is premiere pro 1.5.
    there is also an avid free dv available on the premiere workstation.
    i was thinking that if conversions were necessary we might be able
    to preview the avid media (original files captured on the
    dv express pro 4.3 system) using the avid free dv software and
    then selectively convert files.
    basic process i’m starting to think about is:
    1. consolidate the current project
    2. convert the consolidated omf’s to avi for premiere
    3. export a cmx3600 edl and import it into premiere
    that should reconstruct the avid timeline in premiere.
    we could then perform any tweaks in premiere and, if additional
    media is needed, we could go back to the original 300 hrs that
    were captured in dv express pro 4.3 and are currently residing
    on external drives, use avid free dv to preview it, and convert
    any media we think we need as we need it.
    yes, it would be better and easier to just finish in the avid
    but apparently that system is going away and these are the tools
    they’ll have available for the finish. seem feasible?
    thanks for your help,
    BabaG
  • Kenton Vannatten
    May 3, 2006 at 11:45 pm
    Media from Xpress Pro/DV can not be read on FreeDV so that option is out.
    But you could look into getting Automatic Duck (www.automaticduck.com) this utility allows you to import an Avid sequence/project into Premiere Pro.
    Then you could re-digitized whatever is necessary in Premiere Pro.
    If I think of any other solutions, I will be sure to let you know.
    Kenton VanNatten
