Activity Forums Blackmagic Design Media Express “not supported on this architecture”
  • Media Express “not supported on this architecture”
    Posted by Julius Miller on May 29, 2010 at 5:09 am
    Hi There
    What are the minimum specs for Media Express? When i try to install/run it says it is not supported on this architecture??? Does it require a Mac Pro??? I cant seem to find specs on it… I am running it with a Multibridge Pro which is working fine on m y system…
    Julius
    Julius Miller replied 16 years, 3 months ago 2 Members · 2 Replies
  • Brian Louis
    May 30, 2010 at 11:11 am
    [Julius Miller] “it is not supported on this architecture???”
    What’s the architecture you are running on?
  • Julius Miller
    May 30, 2010 at 11:20 am
    Hi There
    I am running a G5 – Dual 2.3 GHz; 8.5GB Ram, OSX 10.5.8. with a Multibridge connected via PCI express card. Final Cut Studio 2.
    Hope this is enough info…
    I though originally that it was because my monitor did not support 1920×1200 resolution but i then downloaded a previous version of Media Express (V2.03) that allows lower resolutions but got the same error…
    I assume it means you need a Mac Pro but it does not say anywhere in the documentation that this is required???
