Activity Forums Adobe Premiere Pro Media Encoder Won’t Open
  • Media Encoder Won’t Open
    Posted by Chris Holland on August 6, 2010 at 1:04 pm
    I am having a problem with Adobe media Encoder and thought someone might help.
    It has stopped opening at all. Whenver it gets to Loading Windows Media, which I believe is the last thing to load, it crashes out and gives an error message.
    It was working fine until I added an external hard drive to the system in the middle of an export. Then I got the BSOD and afterwards it stopped working. Tried uninstalling and reinstalling to no avail.
    Any thoughts ? Thanks.
    Emrah Celik replied 12 years, 5 months ago 8 Members · 9 Replies
  • 9 Replies
  • Rob Brayton
    September 4, 2010 at 6:27 am
    I had a similar problem with CS5. I ended up deleting the .xml and .pref files in the C:\Users\Login\AppData\Roaming\Adobe\Adobe Media Encoder\5.0 folder and it is much happier now.
    –Rob
    https://www.cinenosin.com
  • Cliff Potter
    November 23, 2010 at 5:54 pm
    Have you had any success in finding out what the problem was?
    Cliff Potter
    Editor
    ERGOMETRICS
  • Chris Holland
    November 23, 2010 at 8:02 pm
    The way we fixed the issue was by deleting the file “Watch Folder Info.xml” that is located in c:\Users\’your account’\appdata\roaming\adobe\Adobe Media Encoder\4.0\
    That has worked for us and we haven’t had any issues since then.
    Chris
    Chris Holland
    Editor/Animation/Design
    hollandedit.com
  • Alexander Welsh
    June 28, 2011 at 2:36 pm
    I am having the same issue with my CS4 Encoder…but my 4.0 folders are practically empty with nothing to move or delete to trick the program into opening. I found another thread that said to reveal/show hidden folders , did so, and still nothing remotely close to what you guys are saying should be moved/deleted.
    Any ideas?
    Alex
  • Alexander Welsh
    June 28, 2011 at 2:39 pm
    Ignore my previous post. I found said folders, fingers crossed i will be able to be as successful as you guys.
  • Ryan Bedell
    January 23, 2012 at 4:27 pm
    I know it’s on old thread, but let me chime in to say that I had Media encoder CS5.5 that was refusing to open and refusing to encode anything from premiere. I deleted the watch folders.xml as recommended above and it worked like a charm. thanks. Just trying to document for the next person who comes along.
    Ryan Bedell
  • Francesco Ciocia
    February 18, 2012 at 8:01 pm
    wow Rob… thanks a lot!!
    not sure what kind of magic that deleting did… but it did work just fine!!
    thanks a lot again
    cheers
    Francesco
  • Jack Simmons
    December 12, 2012 at 11:21 pm
    I’ve done this, and Media Encoder still doesn’t work.
  • Emrah Celik
    April 7, 2014 at 8:56 am
    It has worked for me in cs 5.5 so thank you. I’ve been having this issue for more than 3 months so now I’m a very happy man. Thank you all..
