Activity Forums Adobe Premiere Pro Media Encoder only using 15% CPU, and system slows to cement
  • Media Encoder only using 15% CPU, and system slows to cement
    Posted by Brandon Adams on December 7, 2012 at 12:02 am
    Not sure what’s going on, but trying to export from Premiere CS6 to Media Encoder and very basic 640×360 H264 4 minute clips are taking 40 minutes, only using 15-30% CPU (on 2011 Macbook Pro 2.3 core i7), and the system slows to a cement crawl (had to stop it just to type this post). Nothing else is using any CPU and RAM is 25% free.
    I don’t even know where to begin to troubleshoot. Tried restarting is all so far. Any advice would be greatly appreciated.
    -Brandon
    Vlad Vlad replied 13 years, 7 months ago 2 Members · 2 Replies
  • Brandon Adams
    December 7, 2012 at 7:36 pm
    It seems there is a problem with the Mercury Playback Engine on my MBP. I turned it off and switched to software only mode, and now CPU is screaming at 750% on export and estimated time is about 8 times faster
    -Brandon
  • Vlad Vlad
    January 20, 2013 at 10:26 pm
    Same thing here, when i check the “Render at maximum depth” box PP takes only 60-70% CPU, but when i uncheck the option, PP uses 100% cpu.
    And from 3h30min(60-70% cpu) drops to 2h(100%) rendering time on a 40min clip.
