Activity Forums Adobe After Effects Media Encoder not rendering with accurate frame rate
  • Media Encoder not rendering with accurate frame rate
    Posted by Matthew Wood on May 12, 2015 at 4:43 pm
    edit— just realized that encoder is importing at the incorrect frame rate of 2997. How can I get it to interpret it correctly?
    Hello. I have exported a jpeg sequence at 23.976fps. When I import it into encoder, it defaults it to “match source” and it has a grayed out frame rate of 2997. I uncheck the box, set it to 23.976 and render to h264 but the file is coming out at what is clearly a higher frame rate, most likely 29.97, judging by the difference over time.
    I have rechecked the jpeg sequence by importing directly into AE and it lists it at the correct frame rate and is in sync the entire project.
    I have done this plenty of time before, I am not sure what the issue is. Thanks for help
    Matthew Wood replied 11 years, 4 months ago 2 Members · 2 Replies
  • Walter Soyka
    May 12, 2015 at 4:58 pm
    [Matthew Wood] “edit— just realized that encoder is importing at the incorrect frame rate of 2997. How can I get it to interpret it correctly? “
    “There is a new preference, Indeterminate Media Timebase, under Edit > Preferences > Media that you can use to set the frame rate for sources without an inherent time base, such as image sequences.”
    https://helpx.adobe.com/media-encoder/using/whats-new-2014.html#misc-updates
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Matthew Wood
    May 12, 2015 at 8:09 pm
    @Walter Soyka – Ha, yes, thank you. Exactly what I needed
    Blood type O negative. I bleed zeros and ones
    I dabble on the desktop
    Shifted Leering, Any Perspective
    Shifting Literally All Perceptions
    SLAP
