Activity › Forums › Adobe Premiere Pro › Media Encoder CS6 – H264 Preset
  • Media Encoder CS6 – H264 Preset
    Posted by Abraham Thomas on January 3, 2013 at 12:27 am
    I had a doubt regarding the codecs used by media encoder cs6.
    When I export using any H264 preset, the resulting file shows codec ID as MP42. Shouldn’t it be H264 codec?
    Todd Kopriva replied 13 years, 9 months ago 3 Members · 3 Replies
  • Angelo Lorenzo
    January 3, 2013 at 2:28 am
    You’re looking at the FourCC code. Different implementations from different companies can be assigned different FourCC codes.
    MP42 is the code assigned to the MPEG-4 codec that, at some point, originated from a Microsoft Media developer toolkit. It’s quite possible Adobe is using an implementation based on Microsoft’s code for its non-Quicktime based encoding.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Abraham Thomas
    January 3, 2013 at 4:17 pm
    Thank you very much for your reply. I did not know about this, it was very helpful.
  • Todd Kopriva
    January 3, 2013 at 4:58 pm
    H.264 is equivalent to MPEG-4 (part 10). People often use the terms interchangeably.
    After Effects team blog
