Media Encoder CS5.5 m2v frame size error?
Hi All
I usually use media encoder for BluRay encoding and everything there is fine.
I recently tried to use it for a standard DVD .m2v encode and have got an odd frame size.
I tried using the PAL progressive widescreen high quality preset as that matched my source. The resulting file displays in Quicktime X as 720×576 (1048×576)
I would normally expect 1024×576. Anyway if I import this into DVD Studio Pro it indeed shows a small black bar on the left and right of the picture. (I assume the 24 pixel difference)
Anyone have any ideas why this is or how I can fix/workaround ?
I cant seem to find a custom setting that allows me to force the size of the file to 720×576 (1024×576) either.Thanks in advance
best wishes
Neil
http://www.patience.tv
