Activity Forums Adobe Premiere Pro Media Encoder CS5 – export file name
  • Media Encoder CS5 – export file name
    Posted by Christopher Lowden on April 1, 2011 at 4:31 pm
    Hello
    I am struggling with a silly problem concerning why media encoder CS5 (mac or PC) changes the name of files batch imported from the sequence or composition to an incremented export file name that comes from the project. In short, I add a batch of compositions from AE or a sequences from Premiere into media encoder for a batch encode and I finds that my output file names are not the same as the sequence or comp but media encoder takes the project name. Therefore, I have to rename each file with its sequence name after the export. Very dull. I have about 200 to do. Any ideas how I can force media encoder to not use the project name?
    Many thanks
    Mark Likosky replied 13 years, 11 months ago 2 Members · 1 Reply
  • Mark Likosky
    September 18, 2012 at 5:01 pm
    I just posted about the same problem in AE.
    Wondered if you’ve found a solution
