Activity Forums Adobe Premiere Pro Media Encoder – Could not read from source
  • Media Encoder – Could not read from source
    Posted by Warren Morningstar on March 9, 2011 at 12:05 pm
    OK, it appears that the dynamic link server is acting hinky on my CS5 system. Some weirdness with linked AE compositions inside Premiere, and most notable, can’t reliably encode using the media encoder. In most cases, the encoding fails and returns the message “Could not read from the source.” However, if I encode directly in Pro using “Export” instead of “Queue,” it works fine. Can anyone point me to a fix?
    Thanks much.
    Greg Brand replied 15 years, 6 months ago 2 Members · 1 Reply
  • Greg Brand
    March 9, 2011 at 12:29 pm
    I had the same error once and after much searching
    found that it was the AE plugins installing themselves
    into the adobe common folder instead of the AE plugins folder. After I moves them to the right place, renders worked out fine with AME. Not sure that will work but
    it may be worth a try
    Hope that helps
