Media Encoder compressing really slow.
Hello,
I’m new to After Effects and Media Encoder. I finally got some nice effects going for my youtube video’s and the first video I created in AE, was a short trailer of about 30secs. As such I just rendered it straight from AE and it came out to about 250MB. Perfect!
Now here’s the problem, I created a longer video around 40 minutes long and rendered it via AE again. It was a massive 32GB! Not really something you can upload to youtube quite easily.
So I looked around and it was mentioned that I should compress it further in media encoder. So I looked up the right settings most people said H.264 and just use the youtube preset (HD 1080p 29,97).
Now here’s my problem I left my pc on and went to work, assuming when I got back it would be done, but no cigar. It was maybe 20% in and had 40 hours(!) left. Now I realise compressing can take a long time but is this really normal?
Some info about my PC:
Intel i5-3570K @ 3.4Ghz
16GB DDR3
Windows 7 64Bit
Ati HD7800 series.
And i’m using adobe CS6 suite.So my question to you guys/gals is there a way to speed up media encoder? or is what I’m seeing normal?
Also I was used to sony vegas and that went quite quickly and good once I got the right settings, but I was limited I felt in the effects I could add, hence the switch to AE. But even the short video I made I got the message from youtube that the video could be uploaded faster if I uploaded it in a streamable format (with vegas I used some quicktime setting, so I did the same with AE, but now I have that message again).Another thing I want to add I record my gameplay and such via Mirillis Action, it is very good quality but it does make very big video files (the videos are avi and normally I record about 30mins and depending on the game it will be a video file with a minimum of 10GB, some are even 30GB) but I drag these directly into AE (as I did with vegas) is this a reason why i’m getting such huge files? Would it be better to prerender the videos into a smaller format in vegas or Media encoder before using them in AE?
Allright lot of text, also some questions about AE as well, I hope you can help me because it’s driving me crazy to come back to the PC after 5 hours of work and seeing that it still needs to do a good 40 hours. In fact I’m currently trying it again (disabled preview, I didn’t have that before) and now it’s at about 10% after 40 mins, but still saying it will take 5 hours, and it’s still going up!
Please help, and thank you in advance.
