Media Encoder CC 2014 stops encoding
Hello everyone,
I have an hour long video I have been working on and trying to render/encode as h.264 through Media Encoder CC 2014. I’ve failed to finish encoding the file twice now because it stops encoding. Both times it has stopped in seemingly the same spot. However, there isn’t any particular fx keyframes in this location. I just have two different effects that loop through my composition using the loopOut expression.
The video does not have a lot going on in it. There is an audio file the same length as the video and there is an audio spectrum assigned to it. The only fx are very minor things such as a light sweep every minute and a few layers moving. These are the things assigned with a loopOut expression.
Does anyone have any thoughts about this?
Thanks.
My rig:
Windows 10 (64 bit)
i7-4790k 4.00 Ghz
8gbs RAM
GeForce GTX970
