Activity Forums Adobe Premiere Pro Media Encoder cannot compile movie
  • Media Encoder cannot compile movie
    Posted by Dan Driscoll on October 13, 2010 at 8:48 pm
    Recently did an in place upgrade from Vista 64 Business to Windows 7 Professional. Installed Premier Pro CS5 Production Premium upgrade.
    HP Z800, 2 Xeon 2.8GHz, 12 GB Ram, 64 bit.
    When I export an HD time line or even a single clip to Media Encoder and ask it to make an FL4 @ 2 pass VBR it stops rendering exactly 50% of the way through the process. It will make a single pass.
    I have also run into a problem with the transcription feature. It will transcribe up to the 50% mark , STOP, picture in lower right goes black, then after a few seconds or more it continues to transcribe and finishes the transcription, but no picture in the lower right. This is only a nuisance, but I thought it might be worth mentioning
    I have been on with Adobe for almost 3 weeks back and forth and still do not have a solution. As a note everything worked fine with original 5.0 install and the problems seemed to occur with the 5.0.2 updates.
    ANY suggestions would be helpful.
    Thanks Dan
    Dan at September Productions
    Dan Driscoll replied 15 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
