Activity Forums Apple Final Cut Pro Legacy Media Duration dropping by frames when exported from Avid into FCP
  • Media Duration dropping by frames when exported from Avid into FCP
    Posted by Muthu Ayyeppen on January 27, 2010 at 6:27 pm
    Hello,
    I am in the process of receiving files from an Avid Liquid system into FCP. So, I export the edited sequence in Avid Liquid as Quicktime files (PAL 25fps). It plays fine in quicktime player. But, when I bring the file into FCP it plays the video in slowmotion (when i check the properties of the clip in FCP it shows frame rate as 12FPS). But, if i hit a full render (OPT+R), it renders the timeline and then the video plays fine in its original framerate (but still the properties show as 12FPS), considering this as a secondary problem the main problem i face is the duration of the clip has dropped by couple of frames. This is a real issue.
    Why is this happening? Any ideas?
    Muthu Ayyeppen replied 16 years, 7 months ago 2 Members · 4 Replies
  • Jeremy Garchow
    January 28, 2010 at 1:30 pm
    What kind of QT files are you exporting to from Liquid?
  • Muthu Ayyeppen
    January 28, 2010 at 2:48 pm
    Exporting .mov files with DVPAL codec at 25fps. I have even tried with different field order settings and also as progressive frames. Nothing good!
  • Muthu Ayyeppen
    February 2, 2010 at 10:46 am
    Any help?
  • Muthu Ayyeppen
    February 11, 2010 at 12:54 pm
    Can someone help me out Please???
