Activity Forums Avid Media Composer Media drives say “All Filtered Out”
  • Media drives say “All Filtered Out”
    Posted by Chad Nelson on November 26, 2005 at 10:23 pm
    When I open up the capture tool in Avid Xpress Pro on my mac laptop which is running 10.3.9 Where the drives are, it says that “all drives filtered out” and they are greyed out as well. What is the problem? Thanks…Chad Nelson
    Bob Zelin replied 20 years, 9 months ago 4 Members · 3 Replies
  • Mike G.
    November 27, 2005 at 10:26 am
    I usually edit on Symphony, but I assume this solution should hold true for both Symphony and Xpress:
    Go into your Digitize Preferences (“Capture” prefs on Xpress?), and un-click “Filter drives based on resolution”.
    That should do the trick.
  • Don Logan
    November 27, 2005 at 6:33 pm
    Are you using a shared storage solution such as Unity or lan share?
    If so make sure you have at least one workspace mounted on your shared storage.
    Also ctrl + 5
    will typically open your media creation settings, you can change your drive filtering by system/launch and resolution.
    Hope this helps?
    RD
  • Bob Zelin
    November 28, 2005 at 10:56 pm
    SETTINGS/MEDIA CREATION/Drive Filtering based on resolution. Uncheck this.
    you will be fine.
    Bob Zelin
