Activity Forums Avid Media Composer Media Composer Transition issue
  • Media Composer Transition issue
    Posted by Jeff Kenton on April 21, 2021 at 1:01 am
    Greetings. Im returning to AVID after many years on other platforms and need some help. I have sequence with graphic background on track 1 and some student speakers reduced in size using the Picture in Picture effect on track 2. I want to dip to white in between the students speakers but when I apply the dip to color transition using the quick transition dialog the playback dips the entire video to white. I just want the track 2 video to dip not the track 1 background. Thanks for any suggestions. Jeff
    I’m running AVID MC 2021.3 (software only) on a 2020 iMac 5k.
    Jeff Kenton replied 5 years, 4 months ago 2 Members · 2 Replies
  • Mike Drew
    April 22, 2021 at 3:49 am
    You will need to NEST the V2 layer and apply the fade to white in the nested track and re-apply the pic in pic on the V2 track above the nest. Look up Nesting tracks in the help.
    HTH
    Mike
  • Jeff Kenton
    April 25, 2021 at 6:08 pm
    Thanks Mike. That did the trick.
