Activity Forums Avid Media Composer Media Composer to Media Encoder Workflow
  • Media Composer to Media Encoder Workflow
    Posted by Erick Wilczynski on April 10, 2013 at 6:37 pm
    I am working in a Post house and my Assistant Editor wants to transcode a Media Composer project with Media Encoder.
    I told her a QT reference file would be efficient and there would no loss in quality through the channels. However, I suggest this as an experienced Final Cut editor and a lite Media Composer editor.
    Is there a better workflow for this process?
    Not using Media Encoder is not an option.
    Thank you
    -E
    -vimeo.com/36013051 (reel)
    -RambozMediaGroup.com (production house)
    Peter Groom replied 13 years, 5 months ago 5 Members · 6 Replies
  • Shane Ross
    April 10, 2013 at 6:49 pm
    If it’s non-AMA media…if it is Avid media…then a ref QT works great. Avid cannot export ref QTs of AMA media…must be Avid codecs.
    But you’re right…
    Shane
    Little Frog Post
  • Fred Jean
    April 10, 2013 at 9:14 pm
    Talking about that,
    Not sure if it’s also possible to export QTref with longGOP medias either.
    I beleive it isn’t or it wasn’t. Does someone confirms that? or has it changed?
    Fred.
  • Stig Olsen
    April 10, 2013 at 9:18 pm
    Can you drop in all the 3 files that QT ref creates? Does it treat them as a single clip? Stig
  • Shane Ross
    April 10, 2013 at 9:27 pm
    Correct. Long GOP you can’t do REF QT either.
    Shane
    Little Frog Post
  • Fred Jean
    April 10, 2013 at 9:35 pm
    Thanks Shane.
    Fred.
  • Peter Groom
    April 12, 2013 at 10:43 am
    I can confirm that Ive been unable to export a qu ref from a seq containing Long GOP media or AMA linked media.
    Which brings forth a question.
    I once had a long seq that had a single frame of AMA media left in it by accident, but this was enough to stop me being able to export the qt ref i needed.
    Is there a way if having AVID show / highlight / identify any AMA media from within mountains of non AMA media?
    Peter
    Post Production Dubbing Mixer
