Activity Forums Avid Media Composer Media Composer sudden Proxy problem
  • Media Composer sudden Proxy problem
    Posted by Hendrik Martz on February 3, 2019 at 8:46 pm
    Hello,
    all of a sudden my MC has a problem with proxy workflow.
    I habe HD Prores 422 filed, which I link via AMA into a bin. I then click consolidate/transcode.
    I select the target drive drive and basically follow the steps on frame.io:
    https://blog.frame.io/2017/06/14/proxy-media-avid/
    It workes very well until today. I did everything exactly the same, but now my generated proxy files are offline!
    The files are generated and are in the Avid Media Folder on my external drive but in MC they’re offline and the does not show a location for the proxy files.
    I have no clue why this is, since I follow the exact same steps as before, where i transcoded 60 clips without any issue.
    I am completely lost here.
    I Attached two images showing the bin and the drive where files are.
    When I click on relink, i says “no files where relinked”
    Hendrik Martz replied 7 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
