Media Composer potential bug? White screen instead of black on empty space.
I have noticed a odd behavior on my media composer recently. It happens when I export the sequence as a Quicktime reference file and try to import it in order applications for rendering. All the blank spaces in my timeline should come out as black frames but now they all appear to be white frames in the exported QT file.
I’ve been using Adobe Encoder to do my renders for a long time(no money for Sorenson Squeeze..) Normally, after finishing my edits in media composer, I would render out the timeline as a Quicktime reference file and import that into Premiere to add the finishing titles/logos and stuffs(avid is kinda bad when dealing with a lot of graphics). And then render out the finished H.264 for whatever deliverables in adobe encoder. Everything has been working fine until I updated to version 8.7 or so. Now all the blank spaces in my timeline will appear as white frames in the reference movie, despite the fact that I checked “substitute blank space with black” in the QT reference settings. Tried rendering the complete timeline In/Out before doing the reference render, still doesn’t work. This affects my current project and the only workaround I found is to put a submaster effects onto every single hole in my timeline so that there is no blank space.
Anyone know if this problem? And any solutions or the cause of the problem?
