Activity Forums Avid Media Composer Media Composer 6 and Color Precision
  • Media Composer 6 and Color Precision
    Posted by Bernhard G. on May 4, 2012 at 7:47 am
    Hello,
    Please does Media Composer 6 support 32-bit float color precision rendering?
    I haven’t found this information anywhere. Also I haven’t found the user manual
    for download – the fist thing I’m looking for when interested in a product …
    (AVID should consider that!)
    I’m curious, because FCP-X renders everything in 32bit-float RGB now;
    and every filter and effect does actually support it – i simply like that!
    In other NLEs I found an inconsistency of color precision. Even if the
    the maximum color precision is turned on, then there are still filters and effects
    that are 8-bit only and are corrupting the whole FX stack.
    My specific questions are:
    – Do I need to switch Maximum Quality / maximum color precision “On”
    or does MC always render at maximum color precision and quality
    – What is the maximum color precision MC does?
    bit-deph, YCbCR or RGB?
    – Is every filter and effect suited for maximum color precision?
    Thank You in prior!
    Best regards,
    Bernhard
    Bernhard G. replied 14 years, 4 months ago 3 Members · 4 Replies
  • Daniel Frome
    May 4, 2012 at 11:41 am
    MC does 16bit, not 32bit float.
  • Oliver Peters
    May 4, 2012 at 12:21 pm
    [Bernhard Grininger] “Also I haven’t found the user manual
    (AVID should consider that!)”
    It’s part of the installed files on your hard drive. If you don’t actually have MC installed, you might consider checking out the free trial version for 30 days.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Bernhard G.
    May 4, 2012 at 1:28 pm
    Thank You,
    but before I try a product I enjoy reading the manual!
    In my opinion, manuals should be separately downloadable as PDFs.
    Best regards,
    Bernhard
  • Bernhard G.
    May 4, 2012 at 1:29 pm
    Hello Daniel,
    so MC does 16bit RGB all the time?
    Is every single dissolve, filer and effect capable
    to be processed at actually 16bit?
    Thank You and best regards,
    Bernhard
