Media Composer 3.0 + iMac Help!
Hello. I want to get into Avid, and this is the Mac I want:
24 in iMac
3.06GHz Intel Core 2 Duo
4 GB 800MHz DDR2 SDRAM – 2×2 GB
1TB Serial ATA Drive (7200 rpm)
NVIDIA GeForce 8800 GS w/512MB GDDR3Considering everything works swell on this powerbook:
MacBook Pro 17 in
2.6GHz Intel Core 2 Duo
4GB 667MHz DDR2 SDRAM – 2x2GB
200GB Serial ATA @ 7200 rpmI’d imagine everything should work fine on the souped up iMac; but I gotta stop imagining and start getting advice, right?
Avid Media Composer’s system spec page does not list this iMac:
(https://www.avid.com/resources/qualif…rkstations.pdf)
I called Avid and their tech said that they didn’t think it would work. He said that the engineers that test different systems have not tested this iMac configuration.
I guess this is kinda a last ditch effort to see if anyone is using this computer with Media Composer.
-Or Advice?
Thanks.
