Activity › Forums › Adobe Premiere Pro › Media Cache – Audio Files
  • Media Cache – Audio Files
    Posted by Drew James on October 18, 2012 at 6:45 pm
    Is there a standard where Premiere CS6 won’t create peak files and cache files for my media? I’m having issues where it takes too long for Premiere to create the peak files and takes up too much space when caching files. I understand that Premiere likes 32 bit floating audio files. When I create files at this spec, it still wants to create peak files. Is this the norm?
    Currently I’ve been using Final Cut for years and in the transition of switching to Premiere CS6. I really like Premiere CS6 but running into the issue where it just takes too much time to process all my files. All files are the same: 720p Apple Pro Res PCM audio 16bit 48khz. The issue I run into is when I have lots of files that have up to 8 different audio channels, it just takes too long to process these clips and I have to wait in order to have all audio channels available. I would like to have proper audio files where it does not need to conform and create large cache files for my audio.
    For example, I have 5 clips, all around 1 hour a piece, all have 8 channels of audio. It takes about 20 minutes a piece to fully create peak files and cache files for each clip. Not a big deal if I drop the important clip first and can start working on it several minutes after importing, but if I don’t do this it becomes a pain where I have to wait.
    Hope this issue makes sense to people. Also for full info. Working on Mac OS 10.6.8 12 GB Ram Premiere CS 6.0.2
    Drew
    Drew James replied 13 years, 11 months ago 2 Members · 3 Replies
  • Angelo Lorenzo
    October 19, 2012 at 6:06 am
    Make a cup of coffee and file a feature request https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    This is a common complaint from those switching from Final Cut and there is, currently, nothing you can do about it.
    I wonder, though, if anyone can chime in on the speed of the conform. I just ran a 35min video through with a mono audio track (a webinar sitting on my desktop) and it took 10-15 seconds to conform.
    In Edit > Preferences > Media, setting your cache locations on a different disk from your footage may increase your performance since the conformed audio saves to this location.
    Angelo Lorenzo
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Angelo Lorenzo
    October 19, 2012 at 6:50 am
    I guess if you crunch the numbers on 1 track vs 8 then my machine would also take about the same as yours to conform 5 hours of footage.
    Angelo Lorenzo
  • Drew James
    October 24, 2012 at 1:58 am
    Angelo thanks for the response. I think I’ve narrowed it down to whats causing my issue.
    To explain more the issue, its not the .pek files that are causing the issue, its the .cfa files where Premiere appears to retranscode the audio files.
    I use several tools to transcode all my files to Pro Res 720. The only time I have the cfa file creation is when a file was transcoded in Episode (by Telestream). I believe this is causing my issue.
