media 100i encountered a disk I/O error
Posted by Steph.sch on December 7, 2006 at 10:56 amHello,
The function
Steph.sch replied 19 years, 9 months ago 2 Members · 6 Replies -
Steph.sch
December 10, 2006 at 3:15 pmHello,
Voici le message d’erreur exacte qui apparait lors de l’utilisation de la fonction “Digitize” de la fen
Steph.sch
December 10, 2006 at 3:31 pmHello,
Here the exact error message which appears during the use of the function
Floh Peters
December 10, 2006 at 4:11 pmTry formatting the drive with DiskUtility as HFS+, and make sure that “Journaling” is turned OFF.
Steph.sch
December 11, 2006 at 10:02 pmThank for this first answer.
What is “Journaling” ? Is a fonction of mac OS 9.2 or DiskUtility ?
St
Floh Peters
December 12, 2006 at 7:54 amYou never mentioned tha you were running OS9. There were some FireWire drive problems under OS9, so maybe you are seeing one of those. There is no Journaling option under OS9. Do you use Media 100 XR with the Realtime FX board? Some were reporting problems with FireWire drives and the RealtimeFX board also, I think.
