Activity Forums Media 100 Media 100i Audio Bus
  • Media 100i Audio Bus
    Posted by Paul on May 19, 2006 at 10:24 pm
    This must be simple but I don’t know it. Could anyone direct me to how to use the Bus in Media 100? Is it just for audio? Any literature? It’s not in my manuals.
    What is the bus? All I could find was, “In a flexibly designed mising console, input audio signals are mixed together into a bus and then travel from the bus to an output connector and to other internal mixer functions.”
    Doesn’t do much for me.
    G5, running Media 100i 8.2.2 under OS 10.3, expansion chasis, raid, dual monitors.
    cheers,
    Paul
    Paul replied 20 years, 3 months ago 2 Members · 2 Replies
  • Matty O’tool
    May 19, 2006 at 10:30 pm
    Hi Paul,
    The Master Bus in media100 allows for a “Master gain that will control the over all gain of your Audio tracks on output. It can also be used to apply Audio effects (reverb, EQ, Limiting and such) to all of your audio tracks simultaniously.
    -Hope this helps
  • Paul
    May 20, 2006 at 4:34 pm
    Thanks Matty,
    I’m a novice with some of the audio but your response helped a little. Do you know of any resources (pdfs, online etc.) that might take one through a very simple example?
    Cheers,
    Paul
