Activity Forums Media 100 Media 100 won’t import EPS files
  • Media 100 won’t import EPS files
    Posted by Jason Rogerson on May 20, 2009 at 1:50 pm
    I’ve been trying to import eps files into Media 100. I select EPS file in the drop down import menu, but when it imports it is not visible. I seem to be able to scale it, based upon the edges of the box, but the image is not showing up. Is there something I don’t have switched on in my preferences or some other logical reason this is not working??
    Floh Peters replied 17 years, 4 months ago 2 Members · 3 Replies
  • Floh Peters
    May 20, 2009 at 4:29 pm
    Not sure why it does not work, but I would suggest converting the EPS to e.g. PSD or JPEG in the correct resolution and aspect ratio for your project before importing.
  • Jason Rogerson
    May 20, 2009 at 5:09 pm
    Yeah, me neither. But converting it to a psd or jpg seems to work fine. However, I wonder if the image would be crisper if I could import the EPS since it’s vector based. It looks pretty good as a psd though.
    Thanks Floh.
  • Floh Peters
    May 20, 2009 at 5:11 pm
    [Jason Rogerson] ” I wonder if the image would be crisper if I could import the EPS since it’s vector based.”
    If you prepare the PSD in the right dimensions it will be as crisp as a EPS, since as soon as the file gets imported into the system it gets converted to a pixel-based format anyway.
