Activity Forums Media 100 Media 100 Version 11 Changes/Updates
  • Media 100 Version 11 Changes/Updates
    Posted by Bobby Mosaedi on July 10, 2006 at 9:08 pm
    I requested the release notes from Media100 regarding the bug fixes / changes / updates in version 11 for those who wanted those:
    Fixed Issues from Previous Versions of Media 100
    Media 100 i codec files with Alpha Channels now work on the Video Composition Tracks.
    Adding a clip to a program, where the clip has no classic color filter applied, resulted in
    the clip showing that it must be rendered if in HD or NON real-time in SD.
    When you advance through an audio clip using the arrow keys with audio scan on to find
    the beginning of the audio, you get different start points with the right and left arrow keys.
    Bobby Mosaedi replied 20 years, 1 month ago 5 Members · 8 Replies
  • 8 Replies
  • Kieran Matthew
    July 11, 2006 at 9:50 am
    Hi Bobby,
    Thanks for the info. Nice to see Media 100 cracking through those issues!
    This has me a bit concerned,
    “Media 100 Title Suite
  • Arthur Dent
    July 11, 2006 at 1:16 pm
    As I understand it, This is some of the ‘increased Boris integration’. Title suite is Graffiti, Effects suite is FX and Composite suite is RED. So on the install of the new AJA package, your system key determines which package you’re allowed…
    ~A.D.
  • Kieran Matthew
    July 11, 2006 at 1:27 pm
    Ah yes! Thanks for that Arthur.
    I wonder if you can still install your existing copies of RED et al in the same way as before. If not then that changes the game a little.
  • Arthur Dent
    July 11, 2006 at 2:29 pm
    I believe that you can still install RED separately and it will work exactly as expected.
  • Jose Panadero
    July 11, 2006 at 2:58 pm
    Yes, you can install your RED version and still works the same.
  • Kieran Matthew
    July 11, 2006 at 3:32 pm
    Thanks guys!
  • Michael Slowe
    July 13, 2006 at 9:46 pm
    Bobby, one thing that really bugs me (10.1.3) is having to render a dissolve before seeing if it is right. This is while working in 8bit uncompressed HD. I know that in ‘vertical render” the mix can be seen by scrolling frame by frame but that’s not the same as running it. Also with video in the opacity track opacity changes cannot be viewed without rendering, again a real pain. Am I right and is there any hope of realtime playing of these FX with HD?
  • Bobby Mosaedi
    July 17, 2006 at 11:26 pm
    All the real-time features that were available in SD timelines are now working in HD resolution across ALL codecs, with transitions, clipFX, timeFX, and ColorFX. if these features would have been available at the time of HD’s release, who knows how much farther ahead media100 would have been by now. I just enjoy the ability to mix the multiple codecs. don’t need to think about it anymore.
