Activity › Forums › Media 100 › Media 100 to Final Cut Pro
  • Floh Peters
    December 4, 2008 at 7:03 pm
    [Eric Nicastro] “Is there a way to transfer Media 100 projects into Final Cut Pro? We are on Media 100 version 8.2.3”
    You can do it from V13, via XML export from Media 100. It will export an XML file (sort of a “Meta-EDL”), which can be read by FCP. FCP then will link to the Media 100 media files. And you also can export XMLs from FCP and import them with the media files into Media 100.
