Activity Forums Apple Final Cut Pro Legacy Media 100 to FCP EDL
  • Media 100 to FCP EDL
    Posted by Ashley James on March 19, 2007 at 8:03 pm
    I posted this on the Media 100 forum but no responses. I have a Media 100i 7.5 system and am having trouble importing an EDL to Final Cut Pro. I exported with both CMX 3400 and 3600 from M100 but when I import the EDL into Final Cut all I get is a list of video and audio clips. What I really need is the sequence or timeline so that I can redigitize (batch capture) the clips in the correct order in a timeline
    Any help would be greatly appreciated.
    Ashley
    Kim Rowley replied 19 years, 5 months ago 2 Members · 1 Reply
  • Kim Rowley
    March 20, 2007 at 2:28 pm
    I’ve done this several times and it’s always worked fine for me, so I don’t know where your particular problem lies. I export using CMX 3600 format (the Sony 5000 choice gives you new reel names 001,002 etc) whereas the CMX 3600 tranfers the orginal reel names. When I import into FCP, I get a new sequence with offline media as well as a new bin with all the clips used in the sequence. That’s just to tell you it “should” work… The M100 I export from is version 8.2.3, though I don’t see how that would make a difference. An EDL is an EDL…
    Hope you find the bug!
    Dual 2.7 GHz G5, 4GB RAM, ATI Radeon 9650, Xserve RAID, AJA IO, 2 20″ Cinema Display, FCP 5.1.2, OS X10.4.8
