Activity › Forums › Media 100 › Media 100 to FCP
  • Elliott Dunwody
    March 10, 2008 at 11:27 am
    Or, after reading some of the forums, should I install producer on the FCP system?
    How would that work? Will producer be able to out put via the AJA card?
    Elliott
    Bright Blue Sky Productions
    4811 Rivoli Dr
    Macon, GA 31210
    http://www.brightbluesky.com
  • Floh Peters
    March 10, 2008 at 1:48 pm
    [Elliott Dunwody] “Or, after reading some of the forums, should I install producer on the FCP system?
    This definitely would be the easier option. Producer does not use the hardware, though. There is a software version for people with Aja hardware also, so you could use this on the FCP system and use your Kona card. I have forwarded you the latest Media 100 promo mail.
  • Elliott Dunwody
    March 10, 2008 at 1:55 pm
    Thanks Floh, You are, as always, very good help.
    Elliott
    Got the email 🙂
    4811 Rivoli Dr
    Macon, GA 31210
