Activity Forums Media 100 media 100 sync clips
  • media 100 sync clips
    Posted by Pat Morgan on August 24, 2005 at 8:24 pm
    I have 3 unsync video clips over one audio clip and I don’t know how to sync all the clips together. I can get the middle video to sync with audio but not the other 2.Thanks Pat
    Pat Morgan replied 21 years ago 2 Members · 4 Replies
  • Steve Griffiths
    August 25, 2005 at 2:04 am
    M100 will only allow you top sync 1 video and a stereo audio track together. You can’t have multiple clips
    synced. At least this is that case up until V8.2.2 – not sure about HD but suspect it has the same
    limitation.
    A work around – creat a range over the clips you want synced – and use the ‘export range to bin’ script
    to creat one clip.
    regards
    Steve Griffiths
  • Pat Morgan
    August 25, 2005 at 8:12 pm
    Thanks for responding to my post-I have Media 100 4.5 and your suggestion didn’t seem to be an option. I was in Sidney years back and loved it.
    Pat
  • Steve Griffiths
    August 29, 2005 at 8:30 am
    Hi Pat,
    V4.5 is going back a bit!
    Yes you’re right that will not work on V4.5.
    What you can do though is – create a ‘range’ on the timeline then ‘export range from edit suite’ and then re-import
    the exported file.
    basically this is exactly what the other option I suggested does… except on newer media 100’s the process
    is automated by an apple script. On V4.5 you have to go through each step manually – but it still will work.
    regards
    Steve
  • Pat Morgan
    September 10, 2005 at 3:57 am
    Thanks Steve for your reply- it really has been a great help. I won the Media 100 and an Apple Computer in a drawing a few years back.I tried to take classes but couldn’t find any so I used the tutorial that came with the program. So my knowledge is rarher narrow but mostly I do travel videos and some public service stuff. Now Im working on a film about financial abuse of the elderly and it has more challanges then I’m use to. Is it possible to get your e-mail or is that against the rules?
    Thanks again.Pat
