Activity Forums Media 100 Media 100 Suite v1.0.1 posted
  • Media 100 Suite v1.0.1 posted
    Posted by Wickham Strub on August 21, 2009 at 9:40 pm
    We just uploaded the first point-release for Media 100 Suite.
    There are no earth-shattering fixes in there, unless they relate to your specific workflow, that is 😉
    In this release:
    – Fixed an issue where transitions to and from a MultiClip where removed when choosing “Make Separate Clips from MultiClip”
    – Fixed an issue where HDMI input was not correctly indicated in the Input Channel Mapping window when using the AJA LHi
    – Fixed an issue where some files would import with their audio tracks drastically out of sync.
    – Fixed an issue where transitions between 1080p and 1080i clips would not render correctly
    – VoiceOver tool now shows correct CTI position when a record is aborted
    – HDx-based systems can now acquire 1080psf as 1080p
    – Improved 1080p playback to 1080i output with HDx cards
    – Improved support for Matrox MXO2 line of I/O devices
    Wickham Strub replied 17 years ago 4 Members · 8 Replies
  • 8 Replies
  • Andrew Mehta
    August 22, 2009 at 12:54 am
    Erm, am I missing where on the website this is?
  • Wickham Strub
    August 22, 2009 at 3:40 am
    Sorry about that. Forgot to mention that this replaces v1.0 so all you need to do is download the Suite v1 installer and you’ll find that it installs v1.0.1.
  • Robert Stone
    August 23, 2009 at 5:26 am
    Aloha – Sweet 1.0.1 doesn’t see my Kona LHe card.
    When I reinstall v1.0, it shows it only needs to install
    the Frameworks.
    Hope that helps!
    Blessings,
    Bob
    Robert Stone
    https://www.TaylorCampFilm.com
    https://www.youtube.com/MauiFilms
  • Michael Hanish
    August 23, 2009 at 11:58 am
    Thanks for your message. I would have gone nuts….
    I just installed 1.01 onto my MacPro, 10.5.8, with a Kona 3 and the software didn’t see the board. I shut down, waited, restarted, shut down again, made the usual sacrifices to the usual suspects, restarted again, and still nothing. Did an uninstall of M100, reinstalled v 1.0 and all is well again. A bit scary as a client edit is happening in less than an hour. I’m quite relieved.
    Looking forward to hearing when all is clear,
    Michael
  • Wickham Strub
    August 23, 2009 at 12:30 pm
    Arrrgggghh!!!!!!
    In my haste to get this release availabe to eveyone I forgot to mention perhaps the most significant thing about it…
    It uses the AJA v6.5 Drivers!!!
    I’ll do a fresh post once I’ve had some coffee so those that come after you brave early adopters have a smoother the of it.
  • Michael Hanish
    August 23, 2009 at 2:26 pm
    GREAT, Wick, thanks!!!!
    BTW, are you EVER off duty???
    Michael
  • Michael Hanish
    August 23, 2009 at 2:29 pm
    PS: Forgot to ask a perhaps dumb question, which version of the 6.5 driver, regular or NDD?
    Thanks again,
    Michael
  • Wickham Strub
    August 23, 2009 at 2:51 pm
    Either works. I always use NDD.
