Activity Forums Media 100 Media 100 on Imac
  • Jai Dixon
    March 1, 2014 at 6:28 pm
    Thanks Lukkee Chong…will FCP also need to be set up on a different start up disc because of the matrox mxo2?
    Can FCP and PP exist on the same start up with the mxo2? I use those NLE waaaaaaay less than Media 100.
    Thanks for your help.
  • Tom Gillen
    March 1, 2014 at 9:55 pm
    Hi. On the AJA website, it shows that T-Tap is not supported for Media 100. Has anyone actually used T-Tap with Media100 and been successful? Also the mini monitor from Black Magic is $155 cheaper. Has anyone tried that? Looks like the same box. Thanks.
  • Jai Dixon
    March 2, 2014 at 4:42 am
    Media 100 Ships Suite v2.1.3 with Expanded AJA and Matrox Support
    Media 100 Suite v2.1.3 adds support for AJA’s Io Xt, Io Express, T-TAP, and KONA LHe Plus video I/O hardware as well as Matrox’s Mojito MAX.
    Read this on a post but I have yet to try it.
    I went with the Matrox MXO2 Thunderbolt for my imac.
  • Jai Dixon
    March 4, 2014 at 10:44 pm
    Had a great conversation with the Tech Support at Matrox…Wonderful Customer Service!!!!!!!!
    Lukee turns out that as long as you run Media 100 and Premier cs5.5 the Matrox drivers are compatible.
    If you try to run CS6, then they are not compatible.
    I was going to run CS4 which is not supported by the Matrox at all.
    Have you had any different experiences????
  • Lukkee Chong
    March 7, 2014 at 1:45 pm
    Hi Jai.
    I am running CS6 so that is why I would need two different sets of extensions.
    I don’t use FCP so can’t comment on that setup.
    Cheers!
Page 2 of 2
