media 100 i audio input fader in dig mode
Wickham Strub replied 17 years, 9 months ago 4 Members · 23 Replies
Floh Peters
October 6, 2008 at 3:37 pmTry launching the Application while holding down the “Shift” key.
Floh Peters
October 6, 2008 at 3:40 pmAnd make sure you don´t have any other application running, and no Media 100 Quicktime selected in the Finder.
Joyce Woodworth
October 6, 2008 at 3:53 pmI had a mac guy here and he wants to sell me 500gb of more space… says I need it to run this program.. he has never seen Media 100 before, however. I currently have 150gb of memory. This current project is the biggest I have ever worked on and I did digitize 3.4gb, 3.1 gb, 2.9gb and down from there until I have 47gb left… I did read in the manual after I digitized these larger amounts and it says “to digitize programs greater than 2GB format your disk drives as HFS Plus (Mac OSExtended). I did not do that cause I don’t know how to do that.. Do you think this may have caused a problem? Do you think the Mac Guy is right and I should go have more GB memory on my computer? I am pretty dumbfounded right now. Thanks for your help.. JW
Floh Peters
October 6, 2008 at 3:56 pm[joyce woodworth] “This current project is the biggest I have ever worked on and I did digitize 3.4gb, 3.1 gb, 2.9gb and down from there until I have 47gb left… I did read in the manual after I digitized these larger amounts and it says “to digitize programs greater than 2GB format your disk drives as HFS Plus (Mac OSExtended)”
If you are able to digitize more than 2GB your drive is HFS+ formatted. Your problems are not related to your HD space; there is something else not right with your system.
If you are running V8.2, go to http://www.media100.com and download V8.2.3a from the support section. Reinstall this.
Did you run the Media 100 hardware test? -
Joyce Woodworth
October 6, 2008 at 4:18 pmI have installed the 8.2.3a and I checked the Hardware… it is o.k. Can I call you? Thank you for your help…. I am at a total loss here. JW
Floh Peters
October 6, 2008 at 4:35 pm[joyce woodworth] “I have installed the 8.2.3a and I checked the Hardware… it is o.k. Can I call you? Thank you for your help…. I am at a total loss here. JW”
You should get in touch with Media 100 techsupport.
Joyce Woodworth
November 15, 2008 at 5:48 amHere’s a question for Wickham Strub or any other Media 100 expert out there. If you read this entire thread you will see my problems date back to Oct 5th…. after my media 100 card went bad and then my logic board failed on my last G4 Mac computer, I took out my drives, bought a new/used Mac 1.42 ghz computer and a new/used media 100 card which I have now installed on the computer… I have been trying to get it all working… the computer is fine, it says my media on the drives is all saved however after installing the card, running the hardware test, updating the card, rebooting, running the HW test again, rebooting and then trying to run the Media 100 … when the test on Card 1 (Main)was attempted the message came up: Acceptance Test Failed!, DV-Gear Data Bits Test [137], Part 1: Read: A8 Expect: AA XOR:02
Then if I try to open Media 100 after another reboot, I get the following error: Could not start the application because an error of type -19651 occurred.
I do not have the breakout box connected to the card when I’m running the tests because I am in Minnesota and the breakout box is in Arizona…(I’m returning the computer to AZ next week.) I cannot find a way past this error message to enter the new system key. I’ve tried uninstalling and reinstalling the Media 100 software. Do I need to have the breakout box connected for the Media 100 system to work? Or is there something else we need to try?
I sure would be thankful for some advice. Joyce Woodworth -
Floh Peters
November 15, 2008 at 10:40 am[joyce woodworth] “Here’s a question for Wickham Strub or any other Media 100 expert out there. If you read this entire thread you will see my problems date back to Oct 5th…. after my media 100 card went bad and then my logic board failed on my last G4 Mac computer, I took out my drives, bought a new/used Mac 1.42 ghz computer and a new/used media 100 card which I have now installed on the computer… I have been trying to get it all working… the computer is fine, it says my media on the drives is all saved however after installing the card, running the hardware test, updating the card, rebooting, running the HW test again, rebooting and then trying to run the Media 100 … when the test on Card 1 (Main)was attempted the message came up: Acceptance Test Failed!, DV-Gear Data Bits Test [137], Part 1: Read: A8 Expect: AA XOR:02 “
Actually this sounds like another hardware problem. Have you removed the P6000 card again and checked the connections between the FireWire daughter card and the P6000 board? Are you sure that you have put the P6000 card in the correct PCI slot for the computer you are using?
