Media 100 and El Capitan
Posted by Cornelis Van liempd on October 26, 2015 at 11:31 amBought a new Mac Pro with El Capitano.
Having problems installing Media 110 and Boris.
When is Media 100 ready for El Capitan.Floh Peters replied 10 years, 10 months ago 3 Members · 9 Replies -
Andrew Mehta
October 29, 2015 at 1:55 pmWhat’s the specific problem you’ve encountered…?
I’m about to try installing on El Capitan myself in the next few hours…! ^_^ Perhaps I’ll find out first hand in a moment, ^_^….
Cornelis Van liempd
October 29, 2015 at 5:28 pmDo’nt install El Capitan.
Media 100 and Boris FX/Red are not compatible.
My Mac Pro refuse the installationfor that reason -
Floh Peters
October 29, 2015 at 5:30 pmActually Media 100 Suite 2.1.6 is not *tested* with El Capitan. I am running it on a test system right now, so at least it should install correctly. What kind of errors/messages do you get when trying to install?
Cornelis Van liempd
October 29, 2015 at 8:18 pmThe installation stops. The message:” can not install Media 100″ appears.
Floh Peters
October 30, 2015 at 11:37 am[Cornelis van Liempd] “The installation stops. The message:” can not install Media 100″ appears.
“I initially upgraded my system from Yosemite to El Capitan with Media 100 already installed, so I was not sure how the installer would behave. I just tested the installation under El Capitan, and also got an error message. Let´s see what the reason is.
Cornelis Van liempd
October 30, 2015 at 1:23 pmI went back to Yosemite and wait till the problems are solved by Media 10/Boris.
reg. Cornelis van Liempd, Netherlands -
Andrew Mehta
November 10, 2015 at 6:30 pmWhile Media 100 has not yet been approved for El Capitan, they have at least now made an El Capitan compatible installer, to solve the issue you were having, Cornelis.
I gather you may have been involved with that Floh (along with staff at Boris), in which case, many thanks!
El Capitan Installer:
https://www.media100.com/blogs/news/54922433-media-100-and-el-capitan-installer-update -
Floh Peters
November 11, 2015 at 7:57 pm[Andrew Mehta] “I gather you may have been involved with that Floh (along with staff at Boris), in which case, many thanks!”
Yeah, we worked a little bit on the installer issues. This is related to the new system protection in El Capitan (“rootless”)
