Activity Forums Media 100 Medai 100 & idvd
  • Medai 100 & idvd
    Posted by Mike Lemoniades on July 8, 2008 at 4:43 pm
    Media 100 12.0.2, mac 10.4.11, CS3, QT7 pro. Is anyone having trouble exporting from Media 100 and burning using idvd? When I try it, there is some kind of weird field rendering problem. I’ve exported using every codec combination I can think of. Any ideas?
    Wickham Strub replied 18 years, 1 month ago 3 Members · 4 Replies
  • Floh Peters
    July 8, 2008 at 4:46 pm
    Most likely your source footage is 720*486, while DVDs are 720*480. iDVD scales 720*486 to 480 instead of cropping it, introducing field artifacts. One thing you could try is to export your timeline as a DV stream (0-255 colorspace), which should be 720*480 and therefore not show the problems in iDVD.
  • Mike Lemoniades
    July 8, 2008 at 5:40 pm
    Thank You! I’ve been trying to work this issue out with tech support for about 6 months. Your solution worked perfectly.
    Thank You Again!
  • Floh Peters
    July 8, 2008 at 5:44 pm
    [Mike Lemoniades] “Thank You! I’ve been trying to work this issue out with tech support for about 6 months. Your solution worked perfectly.
    Next time come here earlier 😉
  • Wickham Strub
    July 8, 2008 at 9:14 pm
    Once again Floh, thank you. Next time “I” should ask you earlier too!
    ~Wick
