Activity Forums Maxon Cinema 4D Mechanical joint animations
  • Mechanical joint animations
    Posted by Trevor Navarre on August 29, 2017 at 3:55 pm
    Hello. I have a mechanical animation that I am working on and running into an issue. The contraption has 6 joints that allow it to wrap around a pipe. I thought it would be easy enough using parent constraints and moving each objects axis to the correct location but once it’s animated and I scrub through the objects glitch out and turn into a giant mess. What is the best method for animating this device? Any help would be appreciated.
    11631_flangecuff3dproject2.c4d.zip
    Trevor Navarre replied 9 years ago 2 Members · 2 Replies
  • Brian Jones
    August 29, 2017 at 5:19 pm
    it’s a lot easier to do FK – all the objects are children of the base object so they follow the parent like this
    11632_flangecuffparentedanimtrial.c4d.zip
  • Trevor Navarre
    August 29, 2017 at 6:18 pm
    AHHH! It didn’t click that nesting them would make them follow the hierarchy. Thank you SO much!????
