Activity › Forums › VEGAS Pro › Measuring RMS in Vegas Pro
  • Measuring RMS in Vegas Pro
    Posted by Harry Wright on January 9, 2020 at 1:25 pm
    I’ve got several hours of spoken audio that I’m tampering with, and need all of it to measure between -23dB and -18dB RMS.
    I’m monitoring the LRA and True Peaks, and it looks to me like they’re roughly falling within that bracket, but obviously due to the inconsistent nature of speech, it does often step outside of that range, if only for a moment.
    Is there a way I can monitor RMS directly to see if I’m consistently within that -23dB – -18dB bracket? If not, how would I find out if I am within that bracket?
    Harry Wright replied 6 years, 8 months ago 2 Members · 5 Replies
  • Francois Pénzes
    January 9, 2020 at 4:58 pm
    Hi Harry
    My suggestion is to start by processing your track thru Levelator from The Conversations Network.
    It does absolute wonders to audio, especially speech. I’ve been using it for many years and each time with great results. Plus, it’s FREE ! No strings attached.
    https://www.conversationsnetwork.org/levelator/
    Just make sure that the file you’re dropping in Levelator is either in .WAV or .AIFF. You can use the free software Audacity, for example, to prep your file before dropping it in Levelator. There are numerous tutorial on Youtube on how to use Levelator although it is very user friendly.
    Levelator will automatically save your file to the same place as your original file with the word ”output” added to your original file name. Once you have it normalized, it’s just a matter of adjusting it to the proper level in Vegas.
    Cheers !
    PC Win 10 Pro 64-bit 16gb
    Ryzen 9 3900X 12 Core 4.60GHz
    Radeon RX 5700 XT
    Cameras: Canon XF305 + Canon XH-A1
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • Francois Pénzes
    January 9, 2020 at 5:06 pm
    Hi Harry
    Just noticed that Graham B. esquire had replied to your previous post. (for all of you other curious minds, here’s the link to the post)
    https://forums.creativecow.net/thread/24/1026490
    Cheers !
    Radeon RX 5700 XT
  • Harry Wright
    January 9, 2020 at 5:11 pm
    Hi Francois,
    Thank you for your comprehensive response. I’ve ran the audio through Levelator, and… yeah, seems to sound good. Out of curiosity though, what is it that Levelator is actually doing? Is it fitting the audio into that -23dB and -18dB bracket?
    – Harry
  • Francois Pénzes
    January 9, 2020 at 5:17 pm
    Hi Harry
    After the download links in the link I sent you, there is an explanation of how it works (somewhat) The only thing I know is that it works beautifully.
    Cheers !
    Radeon RX 5700 XT
  • Harry Wright
    January 9, 2020 at 5:20 pm
    Good stuff Francois, seems like a really useful bit of software. Thanks for the recommendation!
    – Harry
