Activity Forums Avid Media Composer MC7 Compatibility Note
  • MC7 Compatibility Note
    Posted by Job Ter burg on June 27, 2013 at 6:56 pm
    One serious heads up for those of you planning to install 7. Bins opened or created in 7 can ONLY be opened in the most recent versions of 6 and 6.5 (being 6.0.4/10.0.4 or 6.5.3/10.5.3 or later). So if you regularly go back and forth between older systems, or if you need to create bins that others are going to need to use, you will need to keep this in mind.
    Greg Dean replied 13 years, 1 month ago 3 Members · 3 Replies
