Activity › Forums › Avid Media Composer › MC6 Sluggish/Lag while Trimming
Charles-etienne Viau replied 12 years, 5 months ago 7 Members · 17 Replies
Alec Gitelman
February 27, 2012 at 11:33 pmi am not using any additional hardware.
2×2.8Ghz Quad-Core Xeon
12 GB RAM
ATI Radeon HD 2600 XT 256 MB -
Matt Osborne
February 27, 2012 at 11:43 pmSo you’re having issues just using the software version, no video out? That’s interesting, if i turn off video out everything works perfectly.
Alec Gitelman
February 28, 2012 at 8:09 pmi may have found the reason.
i’m using AMA with .mov files that use XDCam EX compression. when i opened an exercise project that uses MXF files the stickiness disappeared.
but it still doesn’t make sense, why advertise AMA capabilities if they don’t work well?
Joseph Mastantuono
March 23, 2012 at 10:57 pmNew to Avid (well not really, but haven’t used it in about 6 years), but I’m getting the EXACT same issue. I’m doing a project with the trial to see if I’m going to go with Avid or Premiere as my main editor. Makes working such a drag.
Joseph Mastantuono
http://www.goodpost.net
Color Grading & Post Production Consulting -
Shane Ross
March 23, 2012 at 11:01 pmWOrking with Avid media, or media accessed via AMA, that you haven’t transcoded yet?
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
April 13, 2014 at 7:15 pmHi guys,
Its been 2 years after this last post.
Now its MediaComposer 7.0.3 with AJA IO XT and having the same exact issue the you are talking about (Sluggish/Lag) in timeline and Trim mode.
Anyone got to resolve this one ?
When hardware is ON, its very slow on scrub, when Hardware is OFF the scrub is perfect (real time) (HW / SW) ON / OFF
2 x Avid MediaComposer 7.0.3 with AJA IO XT or KONA 3 (both systems same issue)
10 TB Pegasus Promise RAID
AMA XDCAM EX or MXF DNx145 footage got same issue (1080i59)
OS 10.8.5 (i7 3.4GHz, 16GB 1600MHz DDR3)
AJ Open IO 10.4.9, AJA Driver 10.5.1
