Activity Forums Avid Media Composer MC6 import after effects video with alpha
  • MC6 import after effects video with alpha
    Posted by Mike Jeffs on September 17, 2012 at 9:01 pm
    I’m not sure what is going on i have a Aftter effects video with alpha exported as a animation MOV. when I import into avid importing as a dnxhd 220 with alpha set to invert. my clip comes in at a low quality and it missing some of the subtle background purple
    when i just AMA in the clip the quality is perfect and the subtle purple is there. but obviously the alpha is not.
    here are some screen grabs that hopefully show the difference
    here is the imported clip with alpha set to invert DNX HD 220
    Here is the AMA clip behind the text is a subtle purple background
    and help would be much appreciated
    Mike Jeffs
    Video Coordinator
    BYU-Idaho
    Gary Hazen replied 13 years, 12 months ago 5 Members · 7 Replies
  • 7 Replies
  • Michael Hancock
    September 17, 2012 at 9:04 pm
    Not sure what’s happening, but try rendering out of After Effects as DNxHD-220 with alpha and import it again. Might be something weird happening with the Animation codec.
    Michael Hancock
    Editor
  • Mike Jeffs
    September 17, 2012 at 9:16 pm
    I’ll give that a try
    Mike Jeffs
    Video Coordinator
    BYU-Idaho
  • John Pale
    September 17, 2012 at 9:36 pm
    You probably have After Effects rendering with a premultiplied alpha. set it to “straight”.
  • Daniel Frome
    September 17, 2012 at 11:24 pm
    I’ve heard that AMA does not support alpha channels. Don’t quote me on that, since I cannot remember where I read that. However, worth a try to properly import.
  • Mike Jeffs
    September 18, 2012 at 12:58 am
    Just exporting as dnxhd aith alpha didn’t fix the problem. But the when changing from pre multiplied to straight, then importing without alpha inverted has seem to allow it to come into avid properly.
    Thank you all for your help.
    Although it does make the clip look odd when just previewing in in QuickTime
    Mike Jeffs
    Video Coordinator
    BYU-Idaho
  • John Pale
    September 18, 2012 at 1:19 am
    [Mike Jeffs] “ust exporting as dnxhd aith alpha didn’t fix the problem. But the when changing from pre multiplied to straight, then importing without alpha inverted has seem to allow it to come into avid properly.
    Yes. It may look weird in Quicktime player, but Avid will be happy..as you have noted.
    To Daniel: Yes..you heard correctly…AMA does not support alpha channels.
  • Gary Hazen
    September 18, 2012 at 3:08 pm
    You’ve sorted it out yourself. MC doesn’t support pre-multipled alpha channels.
