Activity › Forums › Avid Media Composer › MC6 hangs on exports
  • MC6 hangs on exports
    Posted by Deleted User on February 3, 2012 at 4:54 pm
    I have a Matrox MX02 with the Max option. I want to be able to export to the Matrox H.264 codec to take advantage of the accelerated speed as well as the lack of transcoding when I take the file to Encore for dvd creation. I have a DNxHD 10 second animation clip in the timeline which is looped to 60 minutes for on-set monitor playback. Everytime I export the full 60 min. timeline the export stalls near the end saying that it’s prepping the “fast start” option even though I have that turned off. The Matrox blinks indicating that the Max option is active during the export.
    If I take the same timeline and export only 30 seonds, the export goes off without a hitch. I haven’t tried other lengths at this time.
    I was thinking that it was a Matrox issue but now that I see others having similiar problems I am changing my mind. I ended up taking a DNxHD ref file to Encore which took many many hours to transcode.
    Do I assume this is a bug or have I set up the preset incorrectly?
    Lee
    SAMDOG Digital Post
    Calgary, Alberta
    Mac Pro 2.66 12-core 16gb ram • FSI LM1760W Monitor • Matrox MX02 • Caldigit HD One 8tb Raid • Avid Artist Transport • Media Composer 5.5 • Final Cut Studio 3 • Premiere Pro CS5
    • Living my life one frame at a time •
    Scott Davis replied 14 years, 7 months ago 3 Members · 3 Replies
  • Ed Cilley
    February 3, 2012 at 7:16 pm
    I can’t address the error you are having, but as a workaround, why not export a short clip (say 1 or 2 minutes) and loop when making the DVD. Either with an End Action pointing to the same file or loopable DVD. I realize there is lag when looping on playback of a DVD, but I don’t think you would have that problem with an end jump.
    _________________________________________________
    Anything worth doing at all, is worth doing well.
    – Philip Dormer Stanhope, Earl of Chesterfield
  • Deleted User
    February 3, 2012 at 7:28 pm
    Thanks. I actually went that route the next morning with a 30 second version as a test. Worked fine.
    But I am more concerned that MC6 stalls on longish exports in general. I spent extra $ on the Matrox Max option to accelerate H.264 exports so I still want to find a solution.
    Lee
    SAMDOG Digital Post
    Calgary, Alberta
    Mac Pro 2.66 12-core 16gb ram • FSI LM1760W Monitor • Matrox MX02 • Caldigit HD One 8tb Raid • Avid Artist Transport • Media Composer 6 • Final Cut Studio 3 • Premiere Pro CS5
  • Scott Davis
    February 5, 2012 at 2:14 pm
    Lee, I’m having the exact same error message with a different setup. Working on MC6, 12 Core Mac Pro. No Matrox though. I’m trying to export a 90 minute sequence made up primarily of XDCAM footage with some ProRess 422 and the same exact thing happens. About 2/3 of the way through it goes to the same error message and hangs there indefinitely. Only solution I found was to break it up into 3 parts. This is a very serious “bug” I need to get QTs out in their entirety.
    Scott Davis
    View Scott Davis's profile on LinkedIn
