Activity Forums Avid Media Composer MC6 exported video to Pro tools.
  • MC6 exported video to Pro tools.
    Posted by Moses Ross on February 13, 2013 at 5:55 pm
    I exported 6 reels of footage that is edited in Media composer 6 in Windows 7.
    Each footage plays about 19 minutes and weighs about 15 GB. So I converted it using Emicsoft video converter with the settings of 720*576 frame size with 24 frame rate per second, which was all done in in Windows 7. When I opened the converted files in I Mac its shows a different resolution like 1024*576 and 23 fps. I tried other video converters like MPEG streamclip and Xilisoft and those didnt work too.Finally I converted them in Adobe premiere pro CS6 with the above mentioned settings. The converted video looked fine when I opened them in Imac, but when I imported it to Pro tools(I mac), the softwares showed that its a corrupted file and cannot be opened.
    So is there a way to open the MC6 video files (Windows 7) in Pro tools (I mac) so that I can finalize my dubbing.
    Moses Ross replied 13 years, 7 months ago 3 Members · 5 Replies
  • Shane Ross
    February 13, 2013 at 6:58 pm
    Why not export as H.264 directly from Avid?
    Shane
    Little Frog Post
  • Michael Phillips
    February 13, 2013 at 7:20 pm
    Have you tried AAF with embedded video media?
    Michael
  • Moses Ross
    February 14, 2013 at 3:33 am
    Actually I can do the export in the required format in MC6 but it will take more time for a single 19 minute video itself. Thats why I had to go for time saving stuffs like exporting it in save as source format and then converting them in video converter.
  • Shane Ross
    February 14, 2013 at 3:56 am
    Here’s how to do it faster than real time…as H.264. Low res, only for review…but it works for everyone I show it to.
    https://lfhd.net/2012/08/31/exporting-low-res-qt-from-avid-fast/
    Shane
    Little Frog Post
  • Moses Ross
    February 18, 2013 at 3:33 pm
    It is really helpful . Thank You.
