MC6 AMA problems with Apple Prores
Hello,
We just finished doing a large show where we recorded all the camera ISOs onto AJA KiPros at quicktime Apple Prores 422 720/60 with 8 channels of audio at Linear PCM 24bit 48hz
We have transferred the folders onto an Isis external storage system connected to our Avid Macs running Lion 10.7.3 and Avid Symphony 6.0.1
When we try to connect to the AJA folders via the AMA option, the clips will load into a bin, but when ever we click on them (right click to load into the preview monitor) we get the spinning ball for a several long seconds. Then the clip will load or the right click menu will appear. But as soon as we try to play or transcode we get the spinning ball followed by an error which reads ‘Serious error as occurred. Immediately save your project and relaunch system’ (or something very similar I forgot to write down the exact words)
The AJA quicktime files are very large, about 100+ gigs and run time around one hour per clip.
I was wondering if anyone has experienced anything similar and what they suggest the work around is?
Thank you
