Activity › Forums › Avid Media Composer › MC4 on PC won’t allow effects on XDCAM footage
  • MC4 on PC won’t allow effects on XDCAM footage
    Posted by Genevieve Baker on June 9, 2010 at 7:01 pm
    Hello all
    We’re having some problems with some footage we shot on the EX3 camera. We upgraded to AVID MC 4 working on an Adrenaline system. We brought the footage in through the AMA and then transcoded and consolidated the footage to make it workable – we thought we wouldn’t need to do this, but we were unable to make the footage work with effects – in particular the speed effect. all was working well until last week when we attempted to work with this footage again and found that it was AGAIN seemingly “unrendered” meaning – there was a green dot on the clip and when we tried to apply the speed effect again it would not work. Very frustrating because we spent the time transcoding and consolidating the footage specifically to use this effect.
    After reading some threads in the forum, we turned off the AMA volume mount, but this still doesn’t seem to help.
    Anyone have any suggestions?
    Thanks in advance,
    Genevieve
    Genevieve Baker replied 16 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • Matt Mullen
    June 9, 2010 at 7:24 pm
    What is the exact version of MC 4 you are using?
    Mac or Windows?
  • Genevieve Baker
    June 9, 2010 at 7:41 pm
    We’re running AVID MC 4 on the Adrenaline system through Windows.
  • Matt Mullen
    June 9, 2010 at 8:11 pm
    Do you know the exact version of MC 4? I don’t know what the issue is but I wanted to see if you were running the latest patch. I think it’s 4.0.5.6
    https://www.avid.com/US/support/downloads/patches
  • Genevieve Baker
    June 9, 2010 at 8:48 pm
    We’re running 4.0.5.1, so I will definitely try the patch. We are working on a project that began quite a few years ago so is native 29.97 and the XDCAM footage is of course in 24 so we had to upgrade to MC4 just to have mixed frame rates in our project. Not sure if this is what the issue is? What do you think?
  • Kris Anderson
    June 9, 2010 at 10:27 pm
    In your media creation settings under the ‘render’ tab there is a “same as source” box…. try selecting that.
  • Genevieve Baker
    June 10, 2010 at 12:46 am
    Under the render tab in media creation – same as source box – is already checked. So that’s not it. Thanks though.
  • Genevieve Baker
    June 10, 2010 at 2:51 pm
    I tried running the patches and that did not help. Any chance we could be having some trouble with the AVID not reading a codec properly?
