Activity › Forums › Avid Media Composer › MC3.0 won’t open MC2.7 projects
  • MC3.0 won’t open MC2.7 projects
    Posted by Manny Vazquez on September 12, 2009 at 1:51 am
    Hello All-
    I’m having a problem opening some old projects in MC3.0. I was cutting using MC2.7 on a Dell Laptop. I then upgraded to MC3.0 running on a MacBook Pro. I have no problem running Avid and starting new projects, however, when I try to open an old project I started on the old computer, the project file is faded and will not open. Any help would be appreciated. Thanks.
    Michael Hancock replied 17 years ago 2 Members · 3 Replies
  • Michael Hancock
    September 12, 2009 at 2:09 am
    Try making a new project with the same name as the old one and copy the bins into it at the finder level.
    Michael
    I’ll be working late.
  • Manny Vazquez
    September 12, 2009 at 1:46 pm
    Nailed it Michael, thanks very much. In retrospect, kind of an obvious solution. Thanks again, much appreciated.
    Manny
  • Michael Hancock
    September 12, 2009 at 3:10 pm
    You’re welcome, and glad that worked.
    Your 2.7 projects should have carried up without issue, but something obviously got messed up. Thankfully Avid’s project creation makes every bin a seperate file so you can recover the import stuff if the project settings get corrupted.
    Michael
