Activity › Forums › Avid Media Composer › MC >> FCP 7 cheat sheet!
Posted by Kris Petersen on October 11, 2011 at 4:49 pmI know, I know… it seems bizarre… but I need any cheat sheets regarding going from Avid MC to FCP7. I’m teaching post this semester and the upper echelon have decided that the students need to know FCP7 in order to take other classes in the department. I have the basics down, and I’m actually having my FCP-proficient students take over the lectures so that I don’t lose them during those sessions.
If anyone can toss me a quick differences-guide or point me to a url that can help that would be great. I am planning to brush up by re-watching the FCP7 to MC ones, and see if I can reverse the information. Sigh…
Chris Harlan replied 14 years, 11 months ago 5 Members · 8 Replies -
Andrew Mckee
October 11, 2011 at 7:22 pmI’ve taught students MC and then FCP a few times. Couple of difference I always point out are that bins can go inside bins (so you don’t need folders) and the subclips won’t allow you to trim past their limits without a command (remove subclip limits). The timeline works quite differently too. They way I think of it is as if synclock is on by default and you have to lock a track in order to stop it being affected by it.
Andrew McKee
Editor/Colourist
Avid Certified Instructor – MC5.5
Apple Certified Trainer – FCP7
Pixelwizard.net -
Andrew Rendell
October 12, 2011 at 1:13 pmWhen I started using FCP after a few years of Avid, transferring over was fairly easy but the things that bugged me were the things that are almost but not quite the same, e.g., Avid’s Add Edit and FCP’s Blade tool (position cursor then click on the tool versus select tool then position cursor and click) and the slider for zooming on the timeline going in the other direction.
Kris Petersen
October 12, 2011 at 1:19 pmYes! That’s a bug I have when I go from PPro to FCP… I miss the ability to cut with a key rather than click.
I also miss the ability to trim with the keyboard using JKL and m,./ Is mouse-trimming the only way to trim in FCP?
Thanks!!
Michael Hancock
October 12, 2011 at 2:14 pm[Kris Petersen] “I miss the ability to cut with a key rather than click.”
Control V will add a cut to every track that has autoselect enabled.
[Kris Petersen] “I also miss the ability to trim with the keyboard using JKL and m,./ Is mouse-trimming the only way to trim in FCP?”
FCP’s trim is nowhere near as nice as Avid’s, but you can use the keyboard to trim once you have your edit points selected. , will trim one frame left and . will trim one frame right. Shift+, and Shift+. will trim 5 frames, I believe.
One thing to point out to your students, if they’re used to Avid, is that FCP’s tracks work kind of the opposite to Avid. In Avid you activate the tracks you want to effect in the record side of the patch panel, whereas in FCP you deactivate or lock tracks you don’t want to effect. Otherwise you have clip collisions and the software will actually prevent you from making the trim or moving the piece of media you want to move. The only way to get around it is to lock every track you don’t want to effect, trim, then unlock in. That’s kind of general and vague, I know, but once I wrapped my head around it I got a lot more comfortable and proficient in FCP.
Michael Hancock
Editor -
Andrew Mckee
October 12, 2011 at 6:47 pmTrimming works almost exactly the same as avid if you double click on an edit to get into the trim edit window. You even get JKL trimming if you select the dynamic button.
Andrew McKee
Editor/Colourist
Pixelwizard.net -
Kris Petersen
October 12, 2011 at 7:16 pmThanks Andrew and thanks Michael! They help a lot, I’m about to go edit on FCP tomorrow so I’ll give those a shot. Very helpful indeed–that’s totally new information to me about keyboard trimming in FCP.
Chris Harlan
October 22, 2011 at 1:12 am[Andrew Rendell] “the things that bugged me were the things that are almost but not quite the same, e.g., Avid’s Add Edit and FCP’s Blade tool (position cursor then click on the tool versus select tool then position cursor and click)”
Just FYI–In FCP 7, CTRL V works much more like Add Edit than the blade tool.
