Activity › Forums › Avid Media Composer › MC 6.5.2 crashing while transcoding: “Segmentation fault” in thread “MainThread”
  • MC 6.5.2 crashing while transcoding: “Segmentation fault” in thread “MainThread”
    Posted by Meg Twomey on May 28, 2013 at 4:55 pm
    I’m on a brand new iMac with OS 10.8.3.
    I’m currently transcoding 720×480 NTSC dv 29.97 QTs in a 1080p 23.98 project using the DNX36 codec.
    Transcoding keeps crashing out, even after updating the MC software to 6.5.2.1. I am getting the “Segmentation fault” error and also this one:
    SWDecodeCvtr::Execute Request()
    CONSISTENCY CHECK FAILURE !?! : []
    Any suggestions? Does anyone know if this is a result of using Mac OS 10.8.3?
    I have a lot of different formats as we are using archival footage from US and elsewhere. So I will need to do the same with the following formats:
    PAL 720X576 25fps
    NTSC dv 720×486 23.98fps
    NTSC dv 720×480 23.98fps
    NTSC dv 720×480 29.97
    Any help is appreciated!
    Kevin P mcauliffe replied 13 years, 4 months ago 4 Members · 3 Replies
  • Noah Todd
    May 29, 2013 at 12:40 pm
    I can suggest two things.
    1) In your project window under the info tab try clear bin memory. It will close all your bins and you may even want to try restarting the software. Then try your transcode again.
    2) Under Media Creation settings in Drive Filtering & Indexing check all three boxes. Filter Network Drives, Filter out System Drive, Filter out launch drive.
    Hope that helps.
    Noah
    Noah Todd
    info [at] noahtodd.com
    http://www.noahtodd.com
  • Ryan Kavanagh
    May 30, 2013 at 2:16 pm
    Did you try to bring the video in by via “AMA linking” then transcoding the video clips once they are in a bin? That method typically encounters far less errors. By the way, if you do bring the video files in this way it is a good idea to keep the original AMA linked clips in your project in a bin somewhere.
  • Kevin P mcauliffe
    May 30, 2013 at 7:06 pm
    Also, don’t forget to update to the current version of MC, 6.5.2.1, which might solve your problem.
    Kevin P McAuliffe
    Creative COW Leader
    kevinpmcauliffe@gmail.com
    Twitter: @kpmcauliffe
