Activity › Forums › Apple Final Cut Pro Legacy › Mb/s in Prores 422hq
Posted by Ofer Geva on February 21, 2013 at 11:25 pmwhat is the bit rate in Prores 422 HQ in 24p?
And also- are all recorders that recored a Prores 422 HQ encoded file record the same bit rate?
Rafael Amador replied 13 years, 7 months ago 4 Members · 3 Replies -
Shane Ross
February 21, 2013 at 11:41 pm[Ofer Geva] “what is the bit rate in Prores 422 HQ in 24p?”
1080p 23.98 is 24.7 MB/s
[Ofer Geva] “And also- are all recorders that recored a Prores 422 HQ encoded file record the same bit rate?”
Yes.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Andrew Kimery
February 21, 2013 at 11:59 pmAJA’s utility shows 1080p24 ProRes HQ to be 24.7 MB/s where as Apple’s white paper gives a target bit rate of 175Mb/s aka 22 MB/s. These equate to 89gigs/per and 79gigs/per respectively (for just video, no audio). ProRes is a variable bit rate codec so there can be small fluctuations in file size between clips of the same duration.
Rafael Amador
February 22, 2013 at 2:50 am[Ofer Geva] ” all recorders that recored a Prores 422 HQ encoded file record the same bit rate?”
No.
Beside the fact that is a VBR codec, it will depend of the hardware you use for the compression.
codecs are sets of rules/recommendations for compression/decompression and they can be implemented with certain variations by different chips, so you may get some differences when using hardware from different manufacturers.
rafael
