MBP + Final Cut Pro = Frame Drop??
I’m editting a budget movie, the footage was recorded using a sony dvd handycam. As some of you might know Macs are always in a fight with sony, so… I had my friend’s PC to convert the DVDs to a “very helpful” format: mpg. So… I had those mpgs converted to MOVs with Sorenson 3 compression.
The question is: is this a bad move? is this what causing the frame drops? This’ the first time I’ve handled Mini DVDs… which I will not prefer again ever in the future…
Please, please, please… I need to get answer right away… If I need to reconvert, what settings would be best? Thanks
Specs:
MacBook Pro 17″ 2.4 GHz Core 2 Duo
2 GB Ram
160 GB 7200 rpm
Maxtor HDD + Coolermaster enclosure (FW400)
